Who Can Rebuild Roosa Master Pump
John
06-03-2004 17:50:43
I have a diesel pump from a JD 5020 that I believe needs rebuilding. Can anyone suggest someone who would be familiar with this 1969 pump. The tractor is very hard to get started the first time, even on a hot day. Starts OK with a squirt of starting fluid in the breather.
Bob
06-03-2004 21:06:03
 Re: Who Can Rebuild Roosa Master Pump in reply to John, 06-03-2004 17:50:43
Go to Stanadyne's website and click on "Dealer Locator".
John
06-03-2004 19:52:44
You can build that pump they are not hard. Most folk will tell you there are hard to time. take it off and mark the rotor without turning it so you can put it back in same place, it will run, get the repair kit fix your pump. I know some folk going to say he is a nut, been there, done that, would roll FIRE 2' out of pipe.
John also
06-06-2004 07:30:34
 Re: Re: Who Can Rebuild Roosa Master Pump in reply to John , 06-03-2004 19:52:44
If the head and rotor are wore out then a "re-seal" kit isn't going to help. Hard start is often head and rotor problems. If the pump has never been rebuilt or replaced it is time for it to give up. Trade it in on a re-built one.
david val
06-04-2004 01:40:59
self repair mayby practical for repairing leaks and replacing the plastic coupler (where exists).
since this pump is suspected for starting problems, before repair it needs to be tested on a testbench by a proffesional. so look for a roosa master experienced shop.
david
