JWS, you said Deere "M".. The Deere "M" & MT are quite different so if you have an "MT" let us know that.. ~The usual cause of the brakes not working on the "M" is an oil soaked brake disk, followed by wear of the apply balls or ball slots & seats at the brake actuating assembly. ~The brakes on the �M� aren�t that difficult to work on but unfortunately the final drive has to be removed first [that�s a pretty good job].. ~Once the final drive is removed then pull the brake assembly apart, look for an oil soaked brake disk due to a leaking shaft seal, or worn [egg shaped] apply balls, or other apparent problems that are causing the brake to not apply strong clamping pressure to the brake disk. ~You can use Brake Clean to clean the disk & operating balls, thrust bearing & other parts but I always just install a new brake disk as it�s just too much work to install a used brake disk.. Test the spring pressure on the thrust bearing & replace any worn balls or ball seats & replace any other parts the balls ride on that are worn.. When assembling the brakes they need to be shimmed [using shim washers] to, I believe around .010�-.015� [I don�t have a manual handy so check that to be sure].. ~I would strongly suggest you get a manual before working on those �M� brakes.. The rather cheap I&T manual [JD-4] actually does a pretty good job of covering the �M� brakes & those I&T manuals are available on line, or at most AG dealers, or even Tractor Supply stores.. The manual will show you pictures [a big help in identifying parts] & give you the basics on that �M� or �MT� brake repair. ~Remember that even when working correctly those �M� brakes leave something to be desired in the stopping department.. Any specific questions just post back or E-Mail.. [email protected]
