Decal Missing???
Michael
06-03-2004 16:25:12
I got to looking at my friends A (also a '48), and his has a decal near the radiator cap that says something to the effect of "High pressure cooling system, use care when opening." I just finished my A, and the decals I got from Jorde's did not include this one. Is it supposed to be there or not? Thanks.
JP
F-I-T
06-03-2004 17:12:28
 Re: Decal Missing??? in reply to Michael, 06-03-2004 16:25:12
Michael:
I may be wrong on the particulars, but it goes something like this.
During the war, Deere could not get brass for their radiators, so they had to use steel. Since the steel could not spin off the heat as fast as brass, they had to use a pressurized cooling system. Deere, and then after market vendors, included that decal in all decal packages over the years, so it gets used on a lot of tractors that did not have pressure cooling systems.
It might have also been used on the late, late, models that also had factory water pumps, but I am not sure.
Someone will certainly stop by with the exact information, but I'm pretty sure this is how the story goes.
Frank
Brokenwrench
06-03-2004 17:08:19
You have a non pressurized thermo siphon system,and no need for the decal.
T213R
06-03-2004 19:59:40
 Re: Re: Decal Missing??? in reply to Brokenwrench, 06-03-2004 17:08:19
The fact is, many decal sellers sell a cheap, unresearched "kit" containing every decal (plus several more) that MIGHT have been used on every styled A or B tractor from 1939-1952. The A and B tractors normally have a NON PRESUREIZED, THERMOSYPHON cooling system. Such tractors do NOT have a water pump (easy to check for) and they have a radiator cap that is about 4 inches across. Afixing the "High pressure cooling system" decal to a thermosyphon tractor tends to make the person who used such a set look a little foolish to those who know the difference. This is unfortunate, but why do you think they are called "correct police"? If you look on your friend's tractor (the one with the radiator warning decal) check and see if it also sports a "CUSTOM POWRTROL" decal. I'll just bet it does and you may be interested to know that while a 520-730 certainly could be equipped with CUSTOM POWRTROL, what the A,B,G and 50-70 tractors were equipped with was called HYDRAULIC POWRTROL. The earlier system used the square cross section rockshaft. The reason that those "kit" decal sets are even available is because John Deere substituted a bunch of incorrect decals for the correct ones sometime after the end of two cylinder production. I actually have a John deere decal kit for an A which is in a John deere parts box, has a JD part number, and is totally incorrect. At the time it was sold, I'd suspect that John Deere had no idea that ANYONE would ever be interested in "Restoring" an old tractor like an A, but that probably someone would want to PAINT one, and so, a sort of decals were cobbled together for sale, mostly by raiding the parts bins. If you bought Jorde Decals, rest assured that YOURS are the actual correct ones and that if you spot any extra decals on other people's tractors---decals you didn't get, don't mention it to them unless THEY ask YOU why YOUR tractor doesn't have them. Then, YOU can reveal YOUR expertise without calling theirs into question (which will at least be more polite than going the "Correct Police " route!
Michael
06-04-2004 15:08:30
 Re: Re: Re: Decal Missing??? in reply to T213R, 06-03-2004 19:59:40
T213R,
Very informative! Thanks a lot for setting the record straight for me. I appreciate it.
JP
T213R
06-03-2004 20:00:42
Wrong place, sorry! The above long post was meant for "Michael"
