Adding on a Secondary remote outlet on late 4020
will
06-03-2004 14:17:19
I am attempting to add on a second outlet box on a console 4020. I have added my lever and linkages. I tried to take the cover off the back with no sucess. I have taken all the bolts out, but still cant remove it. I can move it side to side quite a bit. I examined the plate that I will be adding on, but cant figure out why that cover wont come off. I checked my book, but it only covers early model hydraulics on the dash. Does anyone know why I cant get it off? Thanks so much for your help!!!
WTW
06-03-2004 14:30:32
 Re: Adding on a Secondary remote outlet on late 4 in reply to will, 06-03-2004 14:17:19
will, Take out the bolt that comes in from the back side that is threaded into the plate that you are trying to remove. It is located in the lower right hand corner of plate under and behind rockshaft control valve lever.
