Hydraulic leak in JD M dash
Mark Heidmann
06-03-2004 10:08:42
I have disassembled enough to see the leak in there, but not precisely why it is leaking. It looks like a pinhole in the tubing, because it is spraying out pretty good.
Can I fix this by dissasembling the sections of the leaking line (it is the pressure line) and snaking out the piece through the corner holes in the dash, or do I really have to -- as the book seems to suggest -- remove fuel tank, separate the steering column, and pull the lines from both ends?
Thanks!
Mark
Pat
06-03-2004 14:45:39
 Re: Hydraulic leak in JD M dash in reply to Mark Heidmann, 06-03-2004 10:08:42
Mark,
I had to replace the pressure line on my M last year. No easy task. I had to remove the hood, gas tank, battery & battery box, and the gauges & switch. I didn't remove the dash itself, but I did end up removing the left fender to get everything off and back together. I would guess that it took me eight to ten, over several days, to get the job done. The good news was that Deere had the line to the dealership eighteen hours after I ordered it. Snaking the old line out and the new one in was a real challenge.
The GOOD news is that it went back together without any new leaks. I would find a way to replace all of the clamping hardware while you are in there, and if you have any thoughts about replacing gauges, switch, etc. you might want to do it at the same time. No sense doing all of the disassembly labor twice.
Pat
Pat
Henry J
06-03-2004 10:16:38
Mark
However you are able to get the line out - here is a thought for reassembly. I would make sure that the bushings that go between the line clamps and the line are replaced as the pressure line tends to vibrate.
