730S Diesel Shifter
bent
06-03-2004 08:42:59
While unloading the tractor from the trailer, the shift lever got "stuck". After playing around with it, it will now go into 3rd, 5th and 6th according to the shift quadrant. However, the tractor is really in 1st, 2nd and 4th. I cannot get the lever to move back across to the left. What have I done? Is this a common occurance? I assume the shifter has jumped out of the forks and moved across to the other side.
Clooney
06-03-2004 11:09:15
 Re: 730S Diesel Shifter in reply to bent, 06-03-2004 08:42:59
Bent, fairly common on a well used 730 tractor.. You have probably either forced the shift or hurried the shift & managed to get the under/over drive shifter to move out from under the shift lever's control.
~You can try holding the shift lever both up & down while trying to shift but it�s doubtful that will allow the shift lever to pick the shift fork back up.. [it�s worth a quick try though]..
~Usually what you have to do is pull the trans top shifter quadrant & re-align all the trans shift forks then re-install the shift cover.. Unfortunately it is a fair amount of work on the 730..
~In the future don�t force or hurry the shifts & allow the clutch pulley to slowly rotate as you shift & the problem probably won�t plague you again..
Any further questions just post back or E-Mail..
[email protected]
bent
06-03-2004 12:21:50
 Re: Re: 730S Diesel Shifter in reply to Clooney, 06-03-2004 11:09:15
Thanks Clooney, that's kinda what I thought, just asked in case their was a chance for a "simple" fix. That is my 4th tractor, when will I learn there are no quick fixes?!?
BRent
