620 PTO trouble
Tim
06-03-2004 06:05:12
Anybody been inside the PTO of a 620? Mine continues to spin even with the lever dis-engaged. I removed the adjusting rod from the pedal and moved the lever by hand and it still won't stop the shaft. I can feel the clutch engage when moving forward and back. I tried to grind feed last winter once and the pto slipped then, now it won't shut off. Any suggestions?
Clooney
06-03-2004 06:42:10
 Re: 620 PTO trouble in reply to Tim, 06-03-2004 06:05:12
Tim, a couple of possible problem areas..
1)- The PTO brake is worn out or the clips have come loose..
1A)-The clutch rod from pedal to clutch fork lever is bent [easy to see]..
2)-The PTO clutch plates are warped & won't release properly [common problem]..
3)-The PTO pump seal is leaking trans gear lube into the PTO clutch area & the PTO is full of gear oil now [will need the rear housing removed to replace the pump seal]-- Sniff the PTO oil for signs of gear oil [you know the sulfur type smell of gear oil].. [another common problem]..
4)-Your PTO has the early & late plates mixed together [the early plates tended to not release properly or totally]..
5)- The PTO clutch front pedal has a worn latch off slot or is misadjusted & can�t now travel far enough to allow total release [that probably isn�t the problem if you removed the rod & tried it]..
~It wouldn�t hurt to check & adjust the PTO clutch engagement to see if a simple adjustment will help..
~You should probably pull the PTO clutch out [a fairly easy job] & inspect the brake & clutch plates.. If gear oil is found then replace the PTO pump seal..
Any questions on the above, or on what you find just post back or E-Mail..
[email protected]
Mark Heidmann
06-03-2004 10:03:48
 Re: Re: 620 PTO trouble in reply to Clooney, 06-03-2004 06:42:10
Does this diagnosis strategy also apply to a 1948 JD M?
Thanks for so many helpful answers!
Clooney
06-03-2004 11:12:50
 Re: Re: Re: 620 PTO trouble in reply to Mark Heidmann, 06-03-2004 10:03:48
Mark, the "M PTO is completely different, it doesn�t have clutches, & doesn�t have a pump.. The �M� uses a direct drive shaft from the internal shift collar out through the rear PTO shaft..
[email protected]
Tim
06-03-2004 07:52:39
Thanks,
I'll be tearing into in the evenings.
If it ever quits raining here in PA, I'd like to make a little hay. Of course, so would everybody else!
