JD 'A' hub bolts
JD Fever
06-02-2004 20:37:09
I'm in need of the splined-hub bolts that hold the cast center of the wheels on. Does anyone know where I can obtain them? Also, how can I get broken bolts out of the cast center? Any help is greatly appreciated! Thanks in advance.
JD Fever
Shade Tree
06-03-2004 03:02:52
 Re: JD 'A' hub bolts in reply to JD Fever, 06-02-2004 20:37:09
third party image
The cast steel hub on left cast iron hub on the right. What I did was drill out the center of the broken off bolt. I started with a center punch this is important to get the drilling out process dead center of the broken off bolt. Then start drilling out the bolt with small drill bits working your way up to larger size bits. When you start getting very close the threads, run a tap thru it and this will finish cleaning it out back to like new.
I'm sure John Deere has replacement bolts. They are standard sizes.
Hope this helps.
Pappy
06-02-2004 22:06:17
Which "A" are you working on? I'm not familiar with the "splined" bolts. Please explain.
