4030 or 2840
Pete
06-02-2004 19:18:06
A John deere 4030 and a 2840 are both the same horsepower.... What is the better tractor ??? Does anyone know the pros and cons of both tractors ?? Someone told me that a 2840 could pull more.....
david val
06-03-2004 00:47:50
 Re: 4030 or 2840 in reply to Pete, 06-02-2004 19:18:06
the 4030 got the 'perma clutch',which is a wet clutch. the 2840 uses dry clutch. the 4030 has synchro transmission which is easier to shift then the collar shift of the 2840. on quad range 4030 you get 16 speeds, while in hi-lo 2840 you get only 12.
the standad 40 hydraulic pump has bigger capacity then the standard 2840 pump. you can get 4030 with a 'sound gard' cab, which was the best cab of that era. they both use the same engine. the 2840 is somewhat heavier then a cabless 4030.
david
