Bill, I've seen the prices for the model 50 vary quite a bit depending on where in the country you are. Here in the Southeast they tend to be a little more than say Texas. I purchased my 1953 model 50 about a year and a half ago from someone in VA. I paid $2400 at the time. It was running and was recently painted but needed tires, radiator work, carb work, manifolds, and electrical work. The radiator was completely plugged. The radiator has a replacable "core" which works well, but you will likely bust a few of the many bolts that hold it together. I'm in the process of replacing all the seals and gaskets in the Powr-Trol and PTO systems. Its a 50 year old tractor and if these things have not been done in the last 20 years or so then you can expect to have to do them. In regards to price, whats fair is generally what's fair to you. I think $2400 for my tractor was fair. Not a bargin and not a rip-off. I think there was more wrong with it than the seller knew about. Then again I do all my own wrenching and (with a little help from Clooney and the other guys on this board) pretty much take care of whatever the machine needs. In regards to water comming out of the top of the radiator. I've seen my tractor leak a *small* amount of coolant around the collar where the radiator cap goes whenever the tractor is bouncing around in the field. If your temp gauge is working, it will tell you if the coolant is getting too hot. Some of the earlier 50s (mine included) used shutters in front of the radiator that were opened by a thermostat as a means of controlling the temp. The shutters or mechanism was prone to rusting up. The later 50s use a conventional automotive type thermostat. Correspondingly there were two types of water pumps. Both types of pumps are available. In fact, most parts for the 50 are still available from the dealer. I'd strongly recommend you purchase the John Deere Service Manual and Parts Manual for the 50. Both available in reprint. I have an original owners manual which is well done also. Best of luck with your purchase. You will like the 50. Its a great little tractor. Drop me a response to this post if there are any questions I can help with. John 1953 model 50
