A couple of G question
Howard
06-02-2004 13:53:49
I am working on a 1949 G
#1 is the oil bath air cleaner {can } the same on the A as the G Not the part that mounts to the radator just the can and oil cup are the mounting bolt location all same.
#2 is this normal to have preshrised radator cap with no waiter pump. My 1948 A has large cap but not under presher
#3 are the delco distribiter on the A and G the same the tag is gone on the G and want to get A electronic ingnition for it can I get the same one as that is on my A.
as always thanks for any help offered Howard
Howard
06-03-2004 13:55:40
 Re: A couple of G question in reply to Howard, 06-02-2004 13:53:49
Thanks guys that kinda what I thought but was not shore .I have the Pentronix in the 1948 A.whith the coil and all what a diference it makes in A slow race aswell as just putin around on spark plugs .One moor thougt is their a seal or just a slinger and drain hole on the flywheel side my weeps some on the G and want to adress this be for a compleat savere cleaning and painting thanks again Howard
520-LP
06-02-2004 20:22:54
Question #1 the oil bath is larger on a G. #2 most all G's have a presurized cap [4lb I think] #3 the A and G should have the same dist.Just make sure you order the right ignition [neg or postive gr.]Iwould also get a coil to match the electronic ignition
buickanddeere
06-02-2004 20:50:03
 Re: Re: A couple of G question in reply to 520-LP, 06-02-2004 20:22:54
#1 is the oil bath air cleaner {can } the same on the A as the G Not the part that mounts to the radiator just the can and oil cup are the mounting bolt location all same.
#2 is this normal to have pressurised radiator cap with no water pump. My 1948 A has large cap but not under pressure
#3 are the Delco distributor on the A and G the same the tag is gone on the G and want to get A electronic ignition for it can I get the same one as that is on my A.
Howard
The Delco 1111558 distributor with the magneto type drive runs at crankshaft speed. Used on the A,B,G,50,60 & 70. Takes the Pertronics 1121 module. If positive ground is used, order 1121P12. A 3.0 ohm coil is to be used without a ballast resisitor on 12volts or a 1.5 ohm coil with a ballast.
