Brent, if none of the 12 volt items work (like lights n gauges etc), the problem could well be that you dont have the mid tie point junction where the 2 batteries join in the middle BONDED TO FRAME GROUND. If its not, theres no 12 volts to frame ground from the switches A and B 12 volt inputs as theres supposed to be. One is 12 volts POSITIVE ground and the other is 12 volts NEGATIVE ground. IF THE MID JUNCTION TIE POINT OF THE 2 BATTERIES HAS A JUMPER WIRE BONDED TO FRAME GROUND THAT IS????? ????? ????? ?? The 2 outermost untied battery posts (+ on one - on the other) is 24 volts which feeds the starter and generator, they are each 2 wire non grounded devices. BUTTTTT T where the 2 batteries join in the center, when you run a jumper wire from there to frame ground, that makes the A and B 12 volt feed circuits to your switch. One is 12 volts to positive ground while the other is 12 volts to negative ground. The switch balances your light and other loads off both batteries so they charge n discharge about equal. The only 2 wire non grounded 24 volt devices are the starter n generator, but the 12 volt loads need to be fed from one battery or the other to frame ground, thats why those batteries where they join in the middle has to have that point bonded to frame ground via the use of a jumper wire. If it has none now, I would install an 8 or 10 Gauge wire from that mid tie point to a good solid clean frame ground connection. NOTE: Lights are NOT polarity sensitive and will work off either the A or B Pos or Neg grounded 12 volt battery. HOWEVER, if any gauges are polarity sensitive, they have to be fed from the correct A or B source to work correct. E Mail me [email protected] and I will be glad to e mail you a wirign diagram. Post back or e mail any questions and myself of the other fine gentlemen here will try our best to help you. My bet is that if no 12 volt loads work, you dont have the mid tie point of those batteries tied to frame ground, but that assumes all else is correct and wired right????? ????? if not, all bets off lol. It will be good to hear other ideas or opinions. Good Luck and God Bless you and all the others here. John T Nordhoff in Indiana
