820 Power Steering ????
Gary U in NJ
01-28-2004 07:13:28
Two part question - the first is concerning John Deere Service Manual SM-2018 - Power Steering for John Deere Tractors. I contacted Deere and they say it has been replaced by a SM2045 manual with no discription. Is this the same manual I need for 2 cylinder tractors?
Second question pertains to one of the reasons I'm getting it. My 820 wants to spin the steering all the way to the left. The service manual only discribes relocating the steering control valve body on the housing. When I have done this it centers the steering but it will not allow the wheel to be turned to the left at all. This proceedure, as discribed, only controls steering force and has no impact on centering of the wheels.
So what needs to be adjusted to prperly center the wheels?
Many Thanks!
Gary
Chad in IN
01-31-2004 18:58:21
 Re: 820 Power Steering ???? in reply to Gary U in NJ, 01-28-2004 07:13:28
I'm new to this myself, but I have a similar issue with my 820. I had to replace the input shaft to my power steering pump. The previous owner had used automatic transmission fluid in the power steering system. I drained the system as best I could, and put JD special "early power steering" fluid in. Now the wheels turn to the left on their own and the system foams out the fill cap fairly bad. Neither of these happened before. I have not started to deal with this yet, but I wonder if anyone could offer a direction to start. Would the manual offer what I need?? Any help appreciated.
Thanks so very much,
Chad
Brandon
01-28-2004 13:45:49
I bought the power steering manual recently. It is part number SM2050. Be prepared for price shock. From my dealer, the printed version was $45, or the CD-ROM version was $30. I opted for the CD version, and the quality is good. It covers all two cylinder power steering systems.
Good luck!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Gary U in NJ
01-29-2004 18:25:23
 Re: Re: 820 Power Steering ???? in reply to Brandon, 01-28-2004 13:45:49
Brandon,
Many thanks!
I spoke to my JD dealer and he gave a quote to the manual number I indicated of $110. I shifted to the CD format for the technical and operators manual recently - not cheap but ya gotta have em.
Thanks so much for the corect number.
Gary
Brandon
01-29-2004 20:37:19
 Re: Re: Re: 820 Power Steering ???? in reply to Gary U in NJ, 01-29-2004 18:25:23
Gary,
I don't know if you have ordered yet or not, but the part number I gave (SM2050) is the correct number. I looked up the SM2018 manual (replaced by SM2045) and it is described as the "Fuel Injection Pumps and Nozzles" service manual, which probably wouldn't help your powersteering much! And that also explains the huge price of $110! I don't know how your dealer would NOT notice the difference between a power steering or fuel injection service book!
To order the power steering manual on CD, the part number should be SM2050CD.
Brandon
Clooney
01-28-2004 09:12:06
Gary, I don�t know what to tell you on the manuals.. I haven�t bought one in so long I really don�t know what has been changed to what.. You need to talk to Deere publications on the manual numbers..
~Now on your steering problem.. I can sort of help you there but it is going to take some trouble shooting on your end.. Also keep in mind I haven�t worked on an 820 Power Steering in over 10 years. So if I forget something it will have to be addressed as you get to it..
~It sure sounds like you have worm pins or [a loose or worn helix set screw �early tractor].. You could even have worn steering worm cam, or cam slots or sleeve pin..
~If you have adjusted the steering valve so the wheel stays centered & it won�t then turn left that says the steering valve fork isn�t opening the steering valve when you turn the wheel left.. There is no other adjustment to override the steering valve if it�s properly centered.. That tells you right there you have an internal problem [usually a worn sleeve pin or worn helix screw [early unit]�
~There is only one way to repair it correctly & that is to take it apart & find the worn parts.. There are ways to make it livable [maybe].. One is to adjust the steering valve so it wants to lead left to begin with, that way a worn pin or pin slot won�t actually have to move the sleeve cam & steering fork, all it has to do is allow it do what it already wants to do.. The other is to try adjusting the flow control for more flow.. That allows the steering to move easier & in some cases allows the steering to turn before the sleeve & pins need to apply enough pressure to hang up in their slots..
~Things to check.. you really should get the book so you can identify & properly set & adjust the parts..
1)- see if you have excess end play in the sleeve/worm bearings�Excess worm end play will make centering that steering next to impossible..
2)-if you have the early steering [I don�t have the S/N break handy] remove the helix set screw & grind the point back to be symmetrical & pointed, then adjust it to spec..
3)-Make sure the fork on the steering valve is tight [if that comes loose it is extremely dangerous]�
4)-remove the flow control valve spring & make sure it isn�t broken [I have seen a few that were]..
5)-do a vane by-pass test on the steering system [it�s in the book]..
6)-make sure the steering shaft between the steering wheel & sleeve isn�t bent [that can cause all kinds of adjustment problems] ..that isn�t likely on an 820 though..
~Sorry this really isn�t much direct help but I do believe you will find your problem with a worn sleeve pin [or pins], or worn helix screw [early tractor].. or wear in the pin slot of the sleeve cam, or loose steering valve fork, or excess sleeve/worm end play..
~Your best bet is to see what you can find then post back or E-Mail with questions.. It�s a lot easier for me to answer question than talk you through a full troubleshooting sequence [a lot of those internal sleeve parts are hard to tell a good part from a bad part]�
[email protected]
Gary U in NJ
01-28-2004 10:52:00
 Re: Re: 820 Power Steering ???? in reply to Clooney , 01-28-2004 09:12:06
Clooney,
Many thanks for the response. I do have a call in with my local dealer, he is trying to see if there is more info on the manual.
I appreciate the troubleshooting, I kind of felt it might be a bad component due to the fact no other adjustment of this kind is discussed in the service manual. I'm currently traveling (as usual) for the next week. I'll keep the info posted so everyone can see what comes up.
Hope all is well with you,
Gary
Clooney
01-28-2004 11:06:01
 Re: Re: Re: 820 Power Steering ???? in reply to Gary U in NJ, 01-28-2004 10:52:00
Gary, I don't have it handy here but there is a direct phone line to the Deere service manual publications.. They are as cheap as anyone around & will have a manual in the mail by the next day..
~Maybe someone will post the Deere publications number for you here,, if no one does I will post it later, so check back.. I have been in meetings all day so I�m not near any of my data..
[email protected]
Gary U in NJ
01-29-2004 18:22:15
 Re: Re: Re: Re: 820 Power Steering ???? in reply to Clooney , 01-28-2004 11:06:01
Clooney,
Thanks for the help!
Gary
F-I-T
01-28-2004 14:57:42
Deere Publications:
800-522-7448 for books.
Also, I think you have a step worn in the actuator sleeve and flats on the pins. Maybe even a gummed up actuator valve.
Been there done that, got the T-shirt.
Gotta run!
Frank-in-Pasadena
Gary U in NJ
01-29-2004 18:28:52
 Re: Re: Re: Re: Re: 820 Power Steering ???? in reply to F-I-T, 01-28-2004 14:57:42
Frank,
Sounds like the voice of experience to me!!!
I'll drop you a line when I get back home to find out some of the details you ran into. I'm kind of bopping back and forth between projects with the little time I'm getting at home. Currently in Phoenix for two days and expected home next week.
Again as always, thank you!
Gary
Gary U in NJ
01-29-2004 18:21:03
Frank,
Many thanks!
So what's the deal, are you on the west coast now or traveling back and forth?
Gary
