JD 110 mower drive belt jumps track
Eric
06-01-2004 16:57:46
I have a 1972ish JD 110 lawn garden tractor that throws the front drive belt from it's pully to the rear belt pully when engaging the clutch. I can move the belt back and it will work a while, then all of a sudden there it goes. It would help if I understood how the speed variator system worked I think. Nonetheless, I have replaced the front drive belt but not the rear one yet since the change looks to be a major production. Any assistance would be excellent.
mark
06-01-2004 17:34:16
 Re: JD 110 mower drive belt jumps track in reply to Eric, 06-01-2004 16:57:46
You should replace the variator belts in pairs. The variator works by allowing the belts to walk up or down in the pulley depending on clutch position or lever setting.As the front belt goes down in the variator pulley,the rear belt goes up in it's pulley changing the speed of the input shaft to the trans and vise versa.If you are tossing the belt there could be a guard missing either at the engine pulley,or a tab type belt guide missing at the variator pulley. To replace the rear belt,it is necessary to remove the 3 bolts holding the pulley to the trans,and allow the pulley to drop down enough to get the belt between it and the frame.It's also easier if you remove the seat deck so you can pull the idler pulley up to install the belt.Grease all the pivot point fittings and linkage fittings while it's apart. It isn't too bad a job.
