3010 Hydralic pump
Brad
06-01-2004 11:52:24
hydralic pump is leaking at shaft. I was able to replace the rear seal with hopes it would last the summer, but only lasted a shot while. Question is should I get a rebuilt one or can I rebuild it my self. Considering the work to get it out I'm thinking a rebult. Also is Dealer the best bet for a rebuilt pump? Thanks as always.
jdemaris
06-01-2004 20:27:23
 Re: 3010 Hydralic pump in reply to Brad, 06-01-2004 11:52:24
Its a fairly simple job to take the pump apart and fix it (one hour job on the bench). All you did was replace the low-pressure external seal; you didn't replace the high pressure internal seal. To do so, the shaft has to come out of the pump, and the high pressure seal consists of a quad-ring and teflon backup washer. As far as "rebuilt" pumps go, I say it's probably hogwash. Repaired YES, not rebuilt. I did all the bench work for a couple of Deere dealers on injection pumps, hydraulic pumps, etc. The radial 4 or 8 piston closed-center hydraulic pumps do not have replaceble or repairable cylinder bores where the pistons ride and pump oil. When the bores get worn, there is NO restoring them unless someone has come up with a method of boring them out and/or sleeving them. If someone has, I haven't encountered it yet. I have put many back together though, that were worn/scored yet gave years more of good service. They just did not pump at full rated capacity.
thurlow
06-02-2004 07:28:45
 Re: Re: 3010 Hydralic pump in reply to jdemaris, 06-01-2004 20:27:23
I've never personally seen Worthington rebuild a hydraulic pump. My information came from their web-site (pertinent paragraph pasted below)and what I've been told at their parts counters. As you suggest, it's probably hogwash. I defer to your superior experience/knowledge..... .
""Re-bored Pump Bodies:
Hydraulic pump body bores are carefully measured, those exceeding wear limits are re-bored for oversized pistons, a procedure that is not available at most repair shops.""
jdemaris
06-02-2004 18:45:18
 Re: Re: Re: 3010 Hydralic pump in reply to thurlow, 06-02-2004 07:28:45
It might be true. Deere never offered oversize pistons for their pumps but perhaps someone else has. Last I worked for a dealer was in 1990, and at that time a brand new pump cost around $750. I suspect since then they've gotten a lot higher, so seems it would pay to come up with a way of reclaiming them. With most tractors,though, a pump that has some wear, let's say it only pumps at 3/4 rated capacity, will still pump more oil than most tractors need - unless you've got a HD loader on it. I saw piles of almost new pumps thrown in the scrap metal pile; wish I had them now.
Bob
06-01-2004 13:23:49
If your pump works fine otherwise, you should be able to fix it yourself. Often, though, the shaft will be grooved under one or both of the seals, and need to be replaced.
Don't take apart any more than is necessary to do the job, and use a cupcake tray, or such, to keep all the pistons, springs, and plugs in order, and put them back in their original locations.
