JD 2355 MFWD engine oil
Terry Joe Sprin
06-01-2004 11:02:19
Been using 30 weight oil for year round, but got colder last winter and oil seemed thicker than usual, even down here in the south, longer warmup. Is the Delvac 1300 Super 15-40 suitable for the JD 2355 tractor for year round use? Anyone using this oil, any problems? Using it in the Dodge Cummins HO engine, Ford F-350 diesel okay, would like to use it in the JD 2355 if suitable. My sense is it exceeds the original specs and would be okay for year round use. One JD engineer told me it would be okay and that many of the newer diesel multigrades were quite good compared to older oil formulations and 30 weight was commonly used in the warmer regions of the country. Thanks for the help.
Brokenwrench
06-01-2004 13:25:34
 Re: JD 2355 MFWD engine oil in reply to Terry Joe Sprinkle, 06-01-2004 11:02:19
15-40 is what is recommended for varying temperature applications if you look in the manual.Delvac,Rotella,Deere plus 50 are all good oils and can be used year round where you live.
