4630 too fast! Jumpy Clutch.
pbutler
06-01-2004 10:45:31
I bought a JD 4630 w/Quadrange last fall and have just discovered a potential problem with it.
I want to use it with a batwing but the thing is too fast. Even in the slowest gear at 1/2 throttle it is running a good 5 or 6 mph!
The clutch has always been a bit jumpy on it but I just wrote it off as I had heard that about the old 30 series.
Anyone have any ideas about some adjustment I am overlooking or who has had the same "problem"?
Will
06-01-2004 18:19:45
 Re: 4630 too fast! Jumpy Clutch. in reply to pbutler, 06-01-2004 10:45:31
Here's something to check. Had a 4230 with a similar problem. Put the tractor in A-1 and drive on a level surface at idle, than shift to A-2, You should feel the tractor speed up. it is sometimes hard to feel, so try 3 to 4. then shift 2 to 1. you should feel the up shift down shift between 1 and 2 , 3 and 4. If you don't, than you have a problem with the high low. On this particular 4230 it was stuck in low, a clamp was broke on an internal line and the line had fallen off in the case. One other thing to check is the linkage on the right side of the tractor where the linkage goes into the case. Make sure it is hooked up, as it may have fallen off, or it is internal on the fork that shifts the high/low side.
Brokenwrench
06-01-2004 13:31:36
You must not be using the gears correctly,A-1 should run at about 2mph at rated speed,check your speed chart next to the shifter,and pick a gear that suits you.For 5-6 mph at half throttle you must be in B-4 or C-1 or 2.
pbutler
06-01-2004 13:45:14
 Re: Re: 4630 too fast! Jumpy Clutch. in reply to Brokenwrench, 06-01-2004 13:31:36
No, actually I was very careful to make sure I was in A-1. Was as close to idle as you could get and it was well over 2 mph.
I don't think I am getting faked out on the gears because I can clearly feel it go between all of the ranges on the number and the letter side.
Brokenwrench
06-01-2004 16:02:21
 Re: Re: Re: 4630 too fast! Jumpy Clutch. in reply to pbutler, 06-01-2004 13:45:14
The only thing I can say is you are not in A-1 or someone has changed the ring and pinion in you tractor,in which case it should do about 35-40MPH in D-4. Spin the dial on the speed/hour meter to A-1,and check the ground speed against the rpm you are running.
Russ
06-01-2004 18:19:01
 Re: Re: Re: Re: 4630 too fast! Jumpy Clutch. in reply to Brokenwrench, 06-01-2004 16:02:21
JD4630 OR RABID RABBIT; CAN YOU FIND A DYNAMO WITHIN A DAYS DRIVE? YOU NEED TO PUSH IT THRU ALL THE COMBO'S IN ONE SPOT. WOULD BE NICE TO BRING ALONG A JD 4630 PRO FOR 4 OR 5 HOURS TO SORT OUT A FEW OF THOSE PROBLEMS.
