JD 2440 range selector won't shift
DaveM.
06-01-2004 08:59:15
Hello,
A friend just bought a 2440 and it worked fine. After parking it, he tried to start it and it would not crank. We bypassed the neutral safety cut-off and it starts, but the range selector will not move out of a forward gear. It is stuck and will not move into any of the other forward ranges or reverse, even after driving it around for a while.
Any suggestions would be appreciated.
I offered to let him use my 40T, but he seems attached to the 2440.
Thank you,
Dave
Brokenwrench
06-01-2004 15:45:40
 Re: JD 2440 range selector won't shift in reply to DaveM., 06-01-2004 08:59:15
Probably jumped past the shift gate.Make sure the tractor won't roll.Remove the tin cover and boots over the shifters,the shifter is held in with a snap ring,remove it,lift the shift lever out.Look down in the hole and line up the gates with a long screwdriver.Reassemble the shift lever and try it.If the problem keeps happening the shift rails will have to be replaced. It is also a good idea to put the tractor in park,rather than park it in gear.
DaveM
06-02-2004 08:50:45
 Re: Re: JD 2440 range selector won't shift in reply to Brokenwrench, 06-01-2004 15:45:40
Thanks for the help. I'll give him your fix.
Thanks,
Dave
