2940-no hydraulics
kraig
06-01-2004 08:06:09
I am going to be working on a 2940, it has no hydraulics, it had a leak and got run low on oil, what should I check before I go assuming the pump is bad, can it be air bound, or something simple?
david val
06-02-2004 03:37:58
 Re: 2940-no hydraulics in reply to kraig, 06-01-2004 08:06:09
if you have no hydrauics it could be that the hydraulic pump gets no oil from the transmission pump.
check that the system is full of correct oil, replace the filter and check filter bypass valve as first steps.
david
