CLUTCH DRIVE GEAR 70 D
DAN
06-01-2004 07:40:55
Have the clutch pulley assembly off the tractor, need to pull the drive gear to replace the adjusting bolts and inspect the dogs and toggles. It will not come off with my manual gear puller, any suggestions?
Clooney
06-01-2004 11:06:08
 Re: CLUTCH DRIVE GEAR 70 D in reply to DAN, 06-01-2004 07:40:55
Dan, using & bigger puller [preferably a hydraulic puller] & heat will usually get them off with no damage..
When re-installing BE SURE to support the bottom of the inner hub of the pulley.. If that pulley is just supported on the outer rim pulley damage will probably result..
[email protected]
