GL-1 or GL-5 Oil?
Denny
05-31-2004 20:53:26
I drained and refilled my 530's rearend and tranny this past winter. I used 80-90 GL-5. I didn't know there was a GL-1 and a GL-5. Will the GL-5 harm my tractor? Do I need to replace it? Thanks for any help.
Clooney
06-01-2004 03:12:52
 Re: GL-1 or GL-5 Oil? in reply to Denny, 05-31-2004 20:53:26
Denny, you ask..
Quote: "I drained and refilled my 530's--Will the GL-5 harm my tractor?" >>>
~Denny, GL-5 isn't the best choice for the 2-cylinder's trans but many have been using it without any problems.. Do you need to replace it? Probably not immediately but you really should consider using a GL-1 at the next change.. The 80W90 part is probably worse as that is a much thinner gear oil than straight 90 weight [until it gets real hot, & 2-cylinder gear oil usually doesn�t get very hot]. Again it won�t hurt it but will probably be a bit noisier. The GL-5 could damage the yellow metals in your trans with the right amount of heat & moisture present but that isn�t usually a big problem on lightly used tractors.. For winter usage the 80W90 would be a better shifting gear oil..
[email protected]
