Doug has it on the best place to start, remove the gauge fitting from the governor housing, crank it over without starting it and look for oil there. 1) Substitute known good 2nd oil gauge 2) No, zero pressure is not in the adjustable range. Problem lies elsewhere. 3)??? 4) I suppose it could be, but it would have to have been put on by an ape with a cheater pipe in order to be that tight? Pretty stupid thing to do if you ask me. 5) I'd like one of those myself, especially if I can still get one with good eyes instead of the peepers I'm stuck with now. Oh... you probably meant yet another new governor housing? That seems wasteful and redundant to me. If no oil at the gauge fitting then most likely the last guy in the crankcase didn't attach the piping from the oil pump to the bottom of the governor, next in line is checking for the 'missing' oil pump coupler already mentioned. Then you can look at filter problems and finally dropping the oil pump as solutions to find the real problem here. Your local JD dealer is the best place to start looking for parts, most are still available. Junkyards are also a good bet for used parts. Final thing to do when going back together would be to screw a grease gun into the oil gauge fitting on the governor housing and pumping it up to moderate pressure to see if the tiny, tiny hole that oils the governor gears is open and/or blast it open with grease pressure. Primer easily could obstruct this very small passage which leads away from the fitting hole straight towards the front of the tractor, it's about 1/32" in diameter, if that big.
