Decal placement 720 electric Diesel
jdman(MO)
05-31-2004 18:14:44
Anyone have a clue as to where the decals go on a 720 electric start. Russ
MIKE HANLEY
05-31-2004 20:45:22
 Re: Decal placement 720 electric Diesel in reply to jdman(MO), 05-31-2004 18:14:44
I had the same questions when we redid our 730 Diesel. I knew about where the decals when, but I was looking for EXACT placerment. I have tons books and in all of them not one good enought to judge the EXACT placement. Finally one day I'm sitting at my desk and BINGO!!!!! ! Right in front of me is my ERTL Precistion Classice model of the 730 D3esel. I figured if ERTL didn't have it exact on there Precistion Series, it was close enough for me and I scaled off the model. See if you can get your hands on the Precistion 720 Diesel. It's a neat model with an JD 45 loader and a rear blade and a weatherbrake cab. I have one of those too.
jdman(MO)
05-31-2004 21:57:45
 Re: Re: Decal placement 720 electric Diesel in reply to MIKE HANLEY, 05-31-2004 20:45:22
Thanks Mike, I got the decals from Jorde, I thought he use to give placement instructions, but I guess no more. I can put them where the old ones were if they were correct. Example, have some decals that were not on the tractor, and do the 720 numbers go straight or at an angle? I don/t have a 720 precision, but maybe my nephew does. Russ
OPPS!!!!
06-01-2004 02:07:04
 Re: Re: Re: Decal placement 720 electric Diesel in reply to jdman(MO), 05-31-2004 21:57:45
I guess I should take that neat stuff out of the box once in a while. The Ertl 720 percision was a GAS not a DIESEL. it would be the same except the word "DIESEL" on the hood and the starting instructions which go to the left of the lower dash panel. The 12V goes at the remote electric plug on the side of the battery box.
Greengo
06-03-2004 03:49:05
 Re: Re: Re: Re: Decal placement 720 electric Diese in reply to OPPS!!!!, 06-01-2004 02:07:04
You are correct that the 720 with the loader and blade is gas. Check #10 in the precision series and you will find that is a 720 diesel pony start.
Would like to have seen them make an electric start diesel with narrow front also.
CLW
05-31-2004 23:41:20
The 720 decals slant upwards at, I think, a 28 degree angle with the 7 the low end and 0 at the highest. For some reason a lot of people get it right on one side and then get them backwards on the other side. My book shows the bottom of the 7 to the bottom of the yellow paint on the side of the grill to be ABOUT 5 inches and the decal centered. F-I-T can tell you if that is correct as he did a real good job on his 70. If you have the correct 720 decal (from Jorde I would think you do) they would be hard to put on straight as the 2 should be just a bit higher than the 7 and the 0 just a bit higher than the 2.
CLW
