Electrical Problem
Knucklehead
05-31-2004 16:08:26
Help. Don't ask me how but I managed to accidentally connect the battery terminals backwards while I was replacing the battery in my lawn tractor. I fried one of the smaller wires in the engine compartment that connects up wiht the positive battery wire before I realized what I was doing. I spliced in a new section of wire, connected the battery correctly this time and started the tractor. It ran for about 2 minutes with the battery light on before the same wire fried again beyond where I spliced in the new section. I respliced but now I can't get it to do anything. No turn over, nothing. I checked the fuses and they're OK, but she doesn't show any signs of life. Any suggestions on what I can do to get this running again?
Lee
05-31-2004 22:25:39
 Re: Electrical Problem in reply to Knucklehead, 05-31-2004 16:08:26
Although Bob knows much more about this particular beast than I do, I remain confident that what you 'fried' was the solid state voltage regulator which will need replacing. Solution remains pretty much the same, unplug it and replace entire melted 'wire' with proper fusible link. If it runs without melting wires, then plug in a new regulator. I won't ask, those kinds of things just happen from time to time.
Bob
05-31-2004 16:33:49
From your previous post, I see it's a Deere 240. The first thing you shorted was your voltage regulator. Unplugging the connector off of the regulator will get that short out of the way for testing, and you can replace the regulator later. The other thing I would suspect is that the igntion relay may have been damaged internally. Check the wiring harness very carefully for any other damage. I'm not sure if the ignition switch could have been fried, too, or if the ignition relay would have born the brunt of the damage alone.
The voltage regulator (#M70121) is behind the instrument panel, behind the throttle lever area.
The wire that burned off is most likely a "fusible link". Deere makes a kit (#AM107086) to replace this. Probably, when you replaced this with wire, you "killed" the relay.
Knucklehead
07-03-2004 12:53:58
 Re: Re: Electrical Problem in reply to Bob, 05-31-2004 16:33:49
Thanks for the help.
I tried replacing the voltage regular and the ignition relay but I still can't get it to start. I can't even get the headlights to turn on. Could it be that I fried the solenoid on the starter and am getting no power beyond it at all? The fusible link that you suspected I fried was connected right to the solenoid where the battery cable comes in. I still don't see why I wouldn't get head lights though unless I did burn out the ignitions switch, but the relay I replaced seemed to be fine. I'm kinda stumped (actually still stumped) and any help you can provide is much appreciated.
Thanks!!
