types of oil
bill bradley
05-31-2004 11:54:11
just me the i&tmanual tells how much oils put i need to know what type goes in transmission powershift clutch and first reduction gear thanks
Tyler-MO
05-31-2004 16:59:27
 Re: types of oil in reply to bill bradley, 05-31-2004 11:54:11
If you are refering to a two cylinder with a wet disc powershaft clutch then 30wt motor oil or a good quality trans-hydraulic fluid. The transmission will take 80w-90 gear lube. Try to find GL-1 or non-multi weight gear oil. GL5 will work but it could possibly cause conflict with the brass parts inside your transmission.
Post back if you have more ???'s
