4430 hydraulics chatter
Phil
05-31-2004 11:45:13
I've got a 4430 with the powershift trans. I've got a loader on it and the hyd. chatter when you use it. The three point hitch does the same thing. I also notice that sometimes when I raise the arms and dump the bucket at the same time the arms start coming down. I've put a new seal kit in the hyd. pump that dosen't seem to help at all.
Jake Winn
05-31-2004 23:10:04
 Re: 4430 hydraulics chatter in reply to Phil, 05-31-2004 11:45:13
There could be several problems. If you have a problem in the charge circut or transmission,( the transmission pump not providing enough oil to the main pump) it can cause this. Another thing that will make this happen is a high pressure leak in the system, either pump or rockshaft valve. One more thing that might do it is the main pump has two valve in it that control its operation. One is the stroke control vavle. If a piece of debris gets in it, it will cause the pump to act like this. My suggestion is to have a qualified mechanic come and inspect it, performing hydraulic system tests on the whole tractor. I realize this can be costly, but can save a lot of headache in the long run. Good luck. Let us know what happens.
Lee
05-31-2004 22:38:51
In addition to JMS's advice you might want to replace the suction line going to the pump. 4630 did the chatter thing and finally a hole wore into that hose. When replacing it we found that the dealer had it as 1" where we had 7/8" size. Even stuck with the smaller hose, being new it doesn't chatter near so much.
Also used a bucket of Napa all purpose transmission/hydraulic oil in the total mix which made a dramatic reduction of brake chatter/squawking noise - don't know if it's related at all.
JMS/MN
05-31-2004 15:05:06
First thing to do with a PS with hyd problems is change the two filters. Cut them open and check for flecks of clutch pack material in them. There is a third filter, a screen which you can access after draining oil from the differential. Sounds like your pump is starved for oil.
charles
06-01-2004 00:12:31
 Re: Re: 4430 hydraulics chatter in reply to JMS/MN, 05-31-2004 15:05:06
You don't need to drain the oil if you put a vacuum cleaner hose over the filler ,,no oil comes out !!
