2010 diesel con rod tork
mike
05-31-2004 09:14:11
2010 diesel con rod tork sorry about the lack of info. I sould of put that it, was a diesel the first time around. thanks mike
Tom in Mo.
05-31-2004 18:06:27
 Re: 2010 diesel con rod tork in reply to mike , 05-31-2004 09:14:11
45 footpounds
Mike
06-02-2004 17:39:32
 Re: Re: 2010 diesel con rod tork in reply to Tom in Mo., 05-31-2004 18:06:27
Thank You. got it together now, if i can get it primed it hopefuly will start. when dis. the head and pistons, the fuel pump shaft, "cam shaft" came out, I carfully put the seals back, and lined the dot up end of the blade with the straight line in the pump. comment if you read this Thanks again Mike
