Rolla, assuming the carb has been overhauled correctly, & has the correct internal parts, & the choke is operating correctly your problem sounds like a restricted air intake system.. You said you checked it for a blockage but did you drill the air cleaner spot welds out & actually remove the inner wire mesh? If not that could easily be plugged [a common problem if the power steering has ever leaked fluid into the intake snorkel].. ~Try removing the air inlet pipe to the carb & then trying the tractor under load. If your problem goes away you have a restricted air cleaner.. ~If you still have the problem you will have to look elsewhere.. ~Make sure the manifold heat control valve is set to EXACTLY either hot or cold & not in between.. ~Make sure the mechanical advance in the distributor is working correctly & you are running around 20� total spark advance.. [just put a timing light on the L/H plug wire, then remove the timing hole cover on the flywheel cover, then point the light into the timing hole]..You need to see the spark mark advance smoothly from around TDC to about 20� BTDC as the throttle is moved from idle to full throttle. ~If nothing stands out in the above you might see if you can borrow a different carb to see if that helps [at least that will tell you if your problem is carb related or not].. ~It might not hurt to pull the rocker cover & verify the valves are opening far enough [maybe you have a worn cam]. ~Other than that you might have coked up exhaust valve heads or other exhaust restriction� ~Has the tractor ever run correctly since you have owned it?.. If yes then something went wrong.. If not, then you might have some incorrect parts or incorrect cam timing, or ??? [email protected]
