3010 3rd gear
Skybow
05-30-2004 19:56:06
I have a gas 3010. All the gears work fine except for 3rd. When I put the lever in 3rd and let out on the clutch it grinds as if I didn't get the lever all the way back. Sometimes it goes into 3rd gear but more times than not it won't go into gear. It seems that as the tractor warms up I can get less and less use of 3rd gear. Is there an adjustment I can make or do I need some transmission work done?
Thanks
Huckleberry
05-31-2004 08:59:58
 Re: 3010 3rd gear in reply to Skybow, 05-30-2004 19:56:06
I have a 3020 diesel synchro-range with the same problem. but including 5th gear as well. I discovered that if I shift first into the reverse, then into the gear...I have no grinding, no problem. While this is not a real fix of whatever the problem is ~ it does bypass it. I used it the last couple of years and it works all the time.
david val
05-31-2004 04:17:15
jd synchro transmission have 4 ranges on the lower shaft (differntial drive shaft) and high- low (and reverse) on the top shaft.
3rd gear is first range-high. your problem may be either with the 'high' (which means there should be problems with 5th 7th and 8th gears), or the first range (which means also a problem with 1st gear. check it out. when you come to a conclusion (first range or high), try to adjust the relevant linkage, and if a good adjustment doesn't help- a transmission repair may be required.
david
