Clooney - 730D Fuel Problem Solved
Blake
05-30-2004 13:49:12
Clooney, On the 730D ES, I think the problem in the engine is solved. I tried several things such as turning injectors outwards and checking spray patterns, adjusting racks, swapping pumps, etc. Then I decided to check valve settings and they were perfect at .020, so as my last resort I thought I would check the compression release settings. - On one side the valve came out .050 when I stepped on the decompression pedal.
- On the other the valve came out .090
The suggested setting on the valves are .055-.080
- So I then decided to adjust the linkage to try to meet in the middle at about .070, I did this then went back and checked claerence on my valves, and there was about 40-50 thousandths clearance instead of the recomended 20. After I adjusted everything properly, the tractor seemed to fire better on the weak cylinder. It also had more power and a better klunck to it.
I bought the tractor not running and tore apart. So when it was running good, I drained the tranny oil and replaced it with GL5. I had taken the transmission cover off to inspect the gears and shaft for any major damage but I didn't see any. So I thought I would drive it to check for soundness. I fired it up and put it in 1st, 2nd, 3rd, and then 4th, but in 4th I noticed that every once in a while the tractor would skip and jerk violently and the gear shift would move back and fourth. So I stopped and put it in 5th, it was good so I went to 6th, and in 6th gear it did the same thing was 4th. Thats when I got to thinking that 4th and 6th were in the same slider shaft. So I was wondering what could be wrong with it since I looked it over but didn't see anything. I was thinking maybe it was broken gear teeth. I was wondering if I could place the tractor in 4th or 6th gear and the remove the gear shift and the plate to expose the gates, gears, shafts, etc and drive it around slowly to try to whatch it as it rotated and worked. Clooney, I also want to thank you for all your help. You have taught me alot from not only answering my questions, but also by reading your posts from other questions. I am only 18 and have had to learn most things only from my own mistakes. Then I started asking questions on here and you have been a great teacher to everyone on here including myself. Thanks, Blake
Mike M
05-30-2004 16:09:06
 Re: Clooney - 730D Fuel Problem Solved in reply to Blake , 05-30-2004 13:49:12
I think that you may have a tooth off of 4th and 6th gear which should be the same gear and I think it is under the side cover on the left hand side which is why you could not see it from the top.
