JD 4410 PTO Problem-Please Help!
Max
05-30-2004 10:07:17
My tractor is less than a year old and had been out mowing the field when I noticed the PTO stopped working. The switch is working and the light indicator shows on the dash but the PTO does not turn. Any ideas or suggestions before I have the vendor come tow it to the shop would be greatly appreciated!
Thanks!
Lucas
05-30-2004 17:36:00
 Re: JD 4410 PTO Problem-Please Help! in reply to Max, 05-30-2004 10:07:17
Hi I had a problem like this on a 4310 it turned out to be the solenoid valve itself you have to check the pressures to see if the valve is opening and closing hope this helps
Shorty
07-11-2004 19:33:34
 Re: Re: JD 4410 PTO Problem-Please Help! in reply to Lucas, 05-30-2004 17:36:00
I'm having trouble with the pto stopping after mowing about an hour in high heat. Where is this part located on the tractor?
Thanks,
Shorty in East Texas
Brokenwrench
05-30-2004 16:54:05
Could have knocked the wire off going to the pto clutch itself, a bad seat switch, other wiring problem. Most likely an electrical problem,very doubtfull you did any hardpart damage or you would have heard something.
