2010 con rod tork?
mike rose
05-29-2004 21:49:52
Inf.
Britt
05-31-2004 08:09:05
 Re: 2010 con rod tork? in reply to mike rose, 05-29-2004 21:49:52
Mike,
2010 Gas engine:
Connecting rods 40 to 45 foot-pounds.
Main caps 145 foot-pounds.
Cylinder head 150 foot-pounds
Rocker arm nuts and cap screws (bolts) 30 foot-pounds. This info is from JD 2010 SM-2035 printed 9/63.
Britt
mike
05-31-2004 08:32:53
 Re: Re: 2010 con rod tork? in reply to Britt, 05-31-2004 08:09:05
thanks for the info. but I have a diesel
just got all my parts in started puting it together yesterday. JD closed today because
the hollday or I would give them a ring. If you know of the con rod tork for a diesel 65 late ssn# it would be vvery helpful thanks again
Britt
05-31-2004 09:10:35
 Re: Re: Re: 2010 con rod tork? in reply to mike, 05-31-2004 08:32:53
Mike,
I just checked my manual, and all the torques are the same. Even the mains and the cylinder heads have the same torques. The diesel has 5 main bearings where the gas has only three. The late model con rods have bolts that thread into the rod. The earlier engines had rod bolts with nuts. Either way, they use the same torque according to my manual.
Britt
Good Luck
mike
05-31-2004 09:27:41
 Re: Re: Re: Re: 2010 con rod tork? in reply to Britt, 05-31-2004 09:10:35
Thanks now I can get to work maybe hear it run today, my wife will be happy to have it out of the yard. Thanks Again Mike
2010 Forever !!
