630 oil disappearing..!!! Mr. Clooney..?
Ron
05-29-2004 09:42:04
Fresh rings and rod bearings..no vapor at the vent tube at all.. Used it twice and in an hour (each time)the crankcase oil level went down 1 gallon each time... NO leaks...dry everywhere...!!! I suppose it is going to the 1st reduction... I bet I will find the transmission over-full.. What would you guys suggest as the best way to get this corrected..?? She REALLY pulls hard, with the matched ports,polished and re-shaped valves and polished combustion chambers..!!
Ron
05-29-2004 09:46:33
 Re: 630 oil disappearing..!!! Mr. Clooney..? in reply to Ron, 05-29-2004 09:42:04
If this helps at all, I have serviced the clutch bearing, but did not replace it.. I have some noise in the clutchdrum, even when it is engaged, and I see some run-out when it is spinning.. The splines are in real good shape, and the noise should not be from wear there..
Aaron
05-29-2004 17:08:09
 Re: Re: 630 oil disappearing..!!! Mr. Clooney..? in reply to Ron, 05-29-2004 09:46:33
I would say you have a right hand main bearing oil seal that has gone bad. I had this problem on a 730 diesel once. It isn't a bad job to replace the seal. pulley and First reduction gear cover will have to come off then pull the powershaft drive gear if your tractor has live pto. Really not a bad job. Probobly the hardest part of doing it will be moving your right rear wheel all the way out to remove the pulley and finding a gear puller long enough for the drive gear.
Good Luck
Aaron
Ron
05-29-2004 17:39:10
 Re: Re: Re: 630 oil disappearing..!!! Mr. Clooney in reply to Aaron, 05-29-2004 17:08:09
If I get that far into it..should I go ahead and replace the left hand main bearing..?? I thought there was only a "slinger" on the rt side, to control oil...
Thanks for the help..!!
Ron.
F-I-T
05-30-2004 07:30:19
 Re: Re: Re: Re: 630 oil disappearing..!!! Mr. Clo in reply to Ron, 05-29-2004 17:39:10
third party image
Ron:
The pulley side uses an oil seal, and the slinger is used behind the flywheel. I think you have to be careful when installing th eseal not to block off any inner drains as well.
Frank
Ron
05-30-2004 08:29:38
 Re: Re: Re: Re: Re: 630 oil disappearing..!!! Mr. in reply to F-I-T, 05-30-2004 07:30:19
Thanks F-I-T..
Do you figure I might as well replace the Rt Main bearing, Clutch bearing and bushing..?? I do have some noise in the clutch area that doesent sound right, like loose splines, but I know they are a pretty good fit.. I don't have a torque wrench that goes to 275 ft lbs, but I figure a 3/4" breakerbar and a 4' pipe gets me pretty near, for the flywheel bolt torque..!! Thanks for the input...I hate to go in again, but I guess I have to...!! The pastures are growing, and this is my Big tractor..!! Ron.
F-I-T
05-30-2004 10:49:41
 Re: Re: Re: Re: Re: Re: 630 oil disappearing..!!! in reply to Ron, 05-30-2004 08:29:38
Ron:
You asked:
Well, you would only need to replace a main bearing if it has excessive clearance. Do you have any reason to suspect that?
And....
Noise when it is engaged, disengaged, or both? Engaged noise could be wear in the bushing allowing the pulley to wobble. Disengaged could be that the pulley bearingis noisy. You said "like loose splines, but I know they are a pretty good fit..". Do you require a puller to remove the driver? If so, it's probably a decent fit. Anything else, and it's probably loose.
I like to torque mine, but if you can't, 70 lbs at the end of a 4' pipe is 280#. If you hang your weight on it, you will most likely greatly exceed to torque allowance. Be careful.
Frank
