39 B Broken Oil Ring
Jamie
05-29-2004 08:09:11
Trying to get my tractor ready for a parade and was doing some final painting. Had the crankcase cover off and noticed a piece of metal sticking to the inside of the crankcase. It was a piece of the spring that went under my oil ring. Fished around in the case and found more pieces. Looking at the pistons I think I can tell which one broke. I have a couple questions. One, of course, what kind of damage is going to result from a broken oil ring? I cannot see any damage to the cylinder walls, but it looks like the piston comes back too far and lets the ring come out of the cylinder. I am sure this is what happened and it broke getting forced back in. How far back in the cylinders are the pistons supposed to come? The tractor had been running good previously. I had the block sleeved down to standard size. Was something wrong done in the machining? What will happen if I continue to run the engine with the broken ring? Pretty depressing stuff when I am so close to getting the tractor looking the way I want. Thanks for any advice.
Greg S
05-30-2004 10:05:35
 Re: 39 B Broken Oil Ring in reply to Jamie, 05-29-2004 08:09:11
Jamie - The oil ring is a very important ring. It meters the amount of oil that will lubricate the cylinder walls. Your new sleeve should not allow the oil ring to fall out. If it were mine, I would take it apart and find out what was wrong. The sleeves in my styled B are about 11-3/4" long.
EarlS.
05-29-2004 13:07:02
Jamie, We just covered that problem last week.Is there a ledge at the back of the cyl where they stopped the sleeve.Is your oil ring a 3 piece ring?(SPACER 2 RAILS)If it is you may have to go to a 1 piece oil ring.Earl In Illinois
