Chuck: Here's what I use, but that doesn't make it gospel. 1. Power trol The same wt., grade, and type that I am currently running in the engine. That means Rotella. You can use a modern hydraulic fluid in there as well, especially if you are sharing cylinders. And I like detergent oils after a good break-in of the engine. 2.) rear end/transmission (I have GL-4 90 weight. Will tah work or do I need GL-5)
I'll defer to CLooney on th is one, but I have 85/90 in mine, but will go to 140 wt. next, as it's always warm down here, and I like the noise reduction of the 140. It's just hard to find. 3.) live pto housing The manual says 10 wt. All non detergent oils right? Like I say, I use detergent oils anywhere I can. Also, how do you and where do you drain the final drive housing. I must be blind because i cant find it. I forgot, which tractor are we talking about ? Oh, a '50'. Depending on your serial number, there are two. Check that one isn't up inside of the drawbar frame. The next should be just forward of that area, right about straight down from the front of the brake drums. Finally, is it necessary to blead air out of the power-trol or will it do it itself? It's a gravity system, so all you have to do is to cycle the rockshaft and or remote cylinder a few times to remove any air. Then you need to top off the oil to replace the air you displaced. As far as manuals, I like the ones from Deere. They have reprints available for the '50'. Call them at 800-522-7448. The '50' operator's manual is OMR2033. Hope this helps. Frank
