2840 steering problem
Paul Brown
05-28-2004 11:34:52
I recently purchased a 2840 tractor. Their has been some tranny work done to it but I dont have any detatils on that work. The problem I encountered is the steering coulumn began shaking and leaking at the base. two of the four base bolts were broke, One or more may broke at the time the problem arose. My question is what is the basic operation of the main steering components. Could the broken bolts be a result of deeper problems in the transmission or caused by local vibration of the steering components. I noticed some never seize type sludge app. 1 tsp. I assume is worn metal.
david val
05-29-2004 03:05:05
 Re: 2840 steering problem in reply to Paul Brown, 05-28-2004 11:34:52
the steering unit base bolt get high loads when sreering is held all the way to the left and more commonly shocks from the front wheels through the steering mechanical system. on the other hand, maybe the unit was removed for service and the bolts wern't tightened properly.
i think you should repair the steering unit, install it with 'f' grade bolts tightened securely (prefarably with a torque wrench) and let it run.
david
Paul Brown
06-01-2004 07:03:05
 Re: Re: 2840 steering problem in reply to david val, 05-29-2004 03:05:05
Thanks David,
I replaced the o-rings and gaskets and bolts, but I'm afraid their are other problems. I noticed a vibration in the steering box that I beleive is the piston slapping due to pressure loss in the unit. I need so advice on diagnosing the hydraulic sytem on this tractor ie. pressure testing. The 3-point seems to be starving for fluid, and the steering is pulsing.
