JD 430 Loader
Tweeter
10-22-2003 06:50:10
Can the nuts at the end of the hydraulic tubing, on the left hand side that run along the top member of the loader be removed to paint while the loader has fluid in it? Is there a lot of pressure built up behind them and cant be removed?
Tweeter
10-22-2003 15:46:21
 Re: JD 430 Loader in reply to Tweeter, 10-22-2003 06:50:10
The loader is on a JD 4300 compact tractor.
buickanddeere
10-22-2003 16:00:57
 Re: Re: JD 430 Loader in reply to Tweeter, 10-22-2003 15:46:21
While there likely isn't max operating pressure on the hydraulics while at rest. There could be some from the weight of the loader acting on the cylinders. No fluid ( air or oil) should be opened while under pressure. If the high pressure stream doesn't inject into your flesh,cause cuts or blow dirt into your eyes. The falling equipment can get you.
