Carburetor Backfire
Larry T
05-28-2004 07:26:31
In previous discussions a viewer was told to turn "in" the carb screw while running full throttle if his tractor backfired when going down hills. When I've done this the screw would touch the spring. If it still backfires do you continue to turn it in?. What is the significance of the spring. It doesn't seem to do anything when moved in either direction. When I first tried this it seemed to help but when going down a steep hill it will still backfire.
John T
05-28-2004 13:12:31
 Re: Carburetor Backfire in reply to Larry T, 05-28-2004 07:26:31
Larry, Yes, maybe try it a lil tighter against the stop spring and see what happens. (You were talking about ur top horizontal against spring stop screw, not your carbs vertical needles as turned in or out right???) Its signifiance (your question) is it prevents the throttle plate from slamming closed too tight or too fast is my understanding (the hit, dampen, n spring back operation the screw and the spring undergoes) plus serves as a "soft" throttle idle stop. When shes sittin there idling and those firing power surges occurr, it steadies n smooths the carburetion and idle against the governor action, more like its floated up against that spring versus any dead fixed stop or too tight closure.
If the governor closes down the throttle, it serves as the cushion n damping spring (so she dont slam too closed or too fast),,,,, ,,,,it serves as the idle stop,,,,, ,, and at high vacuum times, like at idle or coast under a closed throttle condition, it dont allow the plate to get shut off totally without offering some back (opening) resistance.
I vaguely remember reading that post you mentioned, seems like Duane may have been helpin ya, see what him or others say about that spring?? Did you already look at your valve lash settings,,timing,,check for vacuum leaks,,try adjustign the carbs load n idle needles???
Let us all know what cures the problem
Good Luck n God Bless
John T
festa
06-03-2004 19:08:28
 Re: Re: Carburetor Backfire in reply to John T, 05-28-2004 13:12:31
You might try to advance the timing, or check to see if it is correct. Late timing will cause it to pop when deaccelerating.
