Hi Low Problems JD 2950
Cow Man
01-27-2004 20:00:25
Recently I have had problems with the Hydraulic/ Transmission oil getting hot when I shift the Hi Low feature to Hi. As long as I keep it in the Lo setting the oil temp is ok. When I go to hi it starts to heat up.
Any insights on my problem?
david val
01-27-2004 23:50:12
 Re: Hi Low Problems JD 2950 in reply to Cow Man, 01-27-2004 20:00:25
check the hi clutch pressure.
when you shift to hi, you not only engage the hi clutch, you also disengage the low brake (which is engaged by spring force).
if there is a pressure drop in the clutch/brake release circuit, a disk slippage may occur that my raise oil temp.
if that's the case the discs are probably burnt and need to be replaced while repairing the pressure loss.
david
twopop
01-27-2004 20:22:49
i would suspect an oring leak in the high range,or warped clutches.
Paul
02-05-2004 22:31:40
 Re: Re: Hi Low Problems JD 2950 in reply to twopop, 01-27-2004 20:22:49
I have replaced some of them little tubes with a hole in them . a pressure check pinpoint the problem quickly .
