Difference between LI's and LA's
Mark Scholten
05-28-2004 04:22:48
I have a 1941 LA. As I was removing the paint, yellow started to show through. Alot of yellow. What are the distinct differences between an LA and an LI? Serial number is gone but I was told it is number 2041.
Mark
Bill D.
05-30-2004 05:25:46
 Re: Difference between LI's and LA's in reply to Mark Scholten, 05-28-2004 04:22:48
John Deere did use a yellow primer on their tractors so, that may be what you see.
JDAOS
05-28-2004 20:50:05
The LA tractor has 24 inch rear wheels with cast centers, The L and LI have 22 inch pressed steel rears. LA`s have a solid steel tube frame, early LI`s could have a thick wall tube frame or solid steel with a solid cast mount for the steering gear. LI`s should have a foot throttle. LI`s have a high seat bracket. LI`s with the JD engine had the letters LI stamped on the flange between the transmission and rear end because the rear end gearing is higher speed than the LA for road travel.
