Generator Question
Doug
05-27-2004 23:22:06
I bought a D-R generator that I hoped to put on my 1947 A. The serial number is 1100018. If anyone can tell me what this might have come off of I would appreciate it. I couldn't find this number in my A parts book.
Thanks, Doug
Clooney
05-28-2004 09:28:28
 Re: Generator Question in reply to Doug, 05-27-2004 23:22:06
Doug, I looked in some of my old Delco repair books & do show a reference to that 0018 generator but no mention of what it was used on, at 45 amps probably a truck or car.. None of the old Deere's used a generator with that much output..
~If you are planning on using that generator you will need to use a voltage regulator [you can't use a generator with that much output with headlight switch controlled field or you will fry your battery]..
~If you are planning long run times [extended field use] on that tractor you should probably use a 4 terminal [L terminal] voltage regulator as that allows the battery to charge without having the lights cause a high charge to the battery..
~As far as I know all normal 6 & 12 volt Delco generators are a type A generator & use an external grounded field to control them so a conventional Deere 3 or 4 terminal voltage regulator will work..
~With that much output that generator would also work on a 12 volt system as long as the RPM�s were kept up a little & a 12 volt regulator was used.
~The preferred way to wire that generator is to use a generator mounted regulator [you will probably have to drill & tap that generator case to use a Deere regulator as most auto type Delco generators aren�t drilled & tapped for the Deere regulator [if you drill be careful you don�t drill into the internal wiring].. You can also mount a flat base generic [type A] voltage regulator to any flat surface but IT MUST have a good ground connection to the generator [a separate ground wire between the gen. & reg. would be preferred]..
~Once the regulator mounting is taken care of you will need to identify all the terminals on the regulator [if your regulator has a wire coming from under the bottom of the regulator it is probably unmarked & that would be the [GEN] wire..
~The other terminals could be marked on the cover or even under the wire retaining clips held on with the terminal screws..
~Once all are identified the�
** [A] post on the generator [will be marked �A� or �Arm�] hooks to the [GEN] terminal or wire on the regulator�.
**The [F] post on the generator hooks to the [F or Fld] on the regulator�.
**The [BAT] terminal on the regulator hooks to the NON battery side of the ammeter.. There should ONLY be one wire on the battery side of the ammeter & that should be the wire running to the starter or battery..
**If your regulator has an [L] terminal that wire hooks to the light switch�s [BAT] terminal.. If the regulator doesn�t have an [L] terminal the light switch [BAT] terminal hooks to the NON battery side of the ammeter..
~When all is wired up per above you absolutely need to polarize the generator� To do that.. FIRST- make sure he battery is installed & fully charged,, then ground the generator�s [F] post,,, Then find the continuously powered wire on the regulator [should be the [BAT] terminal,, then momentarily jump that [BAT] terminal to the [A] post on the generator.. You should see a spark & if so remove the jumper as it�s then polarized..
~Before going too far with that generator MAKE DARN SURE it�s charging direction is correct [not all Delco generator�s turn the same direction to charge.. [sorry my limited data on that 0018 generator doesn�t show charging direction]..
~You might also want to bench test that generator before spending much time with it� To do that�. Use a fully charged 6 volt battery,, then ground the generator�s [F] post to the generator�s frame,,, then hook the battery�s POS post to the generator�s metal frame,,, then run a wire form the battery�s NEG post to the generator�s [A] post,,, that should make the generator run like a motor� Now, remove the [F] post ground & the generator should speed up.. Then re-ground the [F] post & the generator should again slow down.. If it doesn�t motor or speed up your generator has a problem�
Any questions on the above just post back or E-Mail me�
[email protected]
John T
05-28-2004 10:08:32
 Re: Re: Generator Question in reply to Clooney , 05-28-2004 09:28:28
Clooney, Im like you, I wouldnt have any worries about hookin that Generator up he has for 6 or even if he had 12 volts. Ive used many 6 volters on a 12 volt system simply by swapping to a 12 volt VR and NONE EVER WENT BAD. Of course, Im NOT saying its perfect or correct, just that Ive done it and never had any problems. The faster a Generator spins and the higher the Fields magnetic strength (by passing more current through the Field windings) the more it puts out. PS Im pretty sure I read somewhere that DR made BOTH A and B generators??? But unlike you or Duane, I just dont have access to any specs or data.
Good Topic, Im sure we will get him going if that Generators any good that is.
God Bless, John T
John T
05-28-2004 07:02:22
Doug, I just looked through several JD parts catalogs and did not come up with that particular SN you gave. That dont mean you cant use it, however, if its the right voltage and a good working externally field grounded type unit.
What voltage is your tractor??? Did it have a Voltage Regulator on it before?? Does the new Generator have a VR mounted to it or what??
If you have a good working Gen and VR, or even if you had a Gen and cutout relay (but then you would need a field control headlight switch) I can tell you how to wire it up. I prefer a full fledged 3 or 4 wire Voltage Regulator system myself (regardless what any tractor previously used) and if you have a good gen and VR, the wirings a simple task.
Post back or e mail me at [email protected] of your voltage, what you have now and what you had before in the way of a Gen or VR etc., if you have a good working ammeter, and the tractor was originally positive ground, you know. Does your ammeter work?? If you turn lights or a coil ignition (if you have one that is) does the ammeter swing to discharge???
Heres some basics until I hear back from you regarding wirign a Gen and VR:
- BAT terminal on the VR is wired to the LOAD (NOT to Battery) terminal on the ammeter.
- GEN (or ARM) terminal on the VR is wired to the Generators ARM (larger of the 2) post.
- FLD on VR is wired to the Field (smaller of the 2) posts on the Generator.
- If you had a 4 terminal VR with the additional LOAD terminal, the above is the same, its just that tractor loads like lights n ignition n switches are fed from that L terminal instead of the ammeters load side (where wire to VR's BAT is wired)
I have seen 3 brush generators (if thats what you have, but it may be a 2 brush) used on both cutout relay systems (the more usual method) and also with Voltage Regulators.
Then I would POLARIZE (you still at pos ground) by temporarily grounding the Gens Field post to its case. Then momentarily flash jump a wire from the VR's BAT terminal over to its GEN terminal and you should get a small spark.
Sooooo oo, let me know what equipment you had before and now, and your voltage and ammeter and ground and I will help you get wired.
NOTE, for it to work as original, that Gen (for external field grounding) and VR system has to be an A type which uses an external field ground control regulation. Ken at www.classicgenerator.com can fix you up for sure if you cant get the Gen going or its not the correct type. Hopefully someone with some Delco Remy specs can tell you exactly what Gen you have, and then we can get you wired up correctly (if its the right Generator) Sorry, I have access to no DR specs here.
Good Luck n God Bless
John T
Duane Larson
05-28-2004 06:04:00
Doug,
According to SM-2029, the JD Electrical Manual, that generator was not original equipment on any JD, as it is not listed. Looking in an old DR manual, it is apparently a 6V generator with 45 amps cold output. It is not included in a '53 DR catalog, nor later application guides or cross references, so it is not easy to find application info on it (for me, anyway).
