Big D, you ask... Quote: "I have a two cylinder tractor and it fouls plugs a lot I was just wondering are spark plugs any good after you foul them. I just clean mine but they don't seem to have that spark they did before they where fouled" >>> _That really depends on what fouled them & how you clean them.. If the center porcelains are so fuel or oil saturated that you need abrasive to clean them then they will probably never work correctly.. If you can get the coating off of the electrodes & porcelain by only using a solvent & light rubbing with a non abrasive Q-Tip or rag [hard to do] then they will probably function ok.. I have had mixed results cleaning plugs & unless the plug is a multi piece take-a-part like the old Champions about the best thing I have used is either brake clean, or alcohol, or lacquer thinner [no abrasive used].. ~I use Champion plugs in a lot of my old tractors & haven�t had any more trouble with those than any of the other brands.. My personal opinion is that the plug brand isn�t nearly as important as the plug�s HEAT RANGE.. [the HOTTER the better].. ~The modern gasoline is blended for higher compression engines, & to meet evaporative emission regulations, & to protect a vehicle�s emission system.. Therefore it doesn�t work that well [ignite easily] in the old low compression weak spark 2-cylinder tractors.. ~The answer seems to be HOTTER SPARK PLUGS,, [he hotter the better].. ~You didn�t give us your Deere tractor model or year so we really can�t recommend a specific plug, but if your [Deere] tractor uses a� 7/8� plug- I would recommend Champion W89D, or Autolite 3077 18 mm plug- I would recommend Champion D-23, or Autolite 388, or A-C C88L 14mm plug- post back or E-Mail me & give the year & model.. ~I have also found that adding a second plug gasket under the spark plug will raise the heat range slightly & that can go a long ways towards preventing plug fouling.. The secret is: to not foul the plugs in the first place. ~Sometimes it isn�t even the plug�s fault�. The spark plug wires on the old 2-cylinder Deere�s MUST BE solid metal core [the newer automotive carbon core plug wires are sure to increase the plug fouling problem]..
~I don�t try to run my 2-cylinder tractors real lean as I don�t have any problems fouling the plugs to begin with.. Sometimes trying to run too lean can be counter productive as it takes quite a bit more spark voltage to spark across the electrode gap in a lean environment & it takes a larger more powerful spark to ignite a lean mixture consistently.. ~I have also found that running the plug electrode gap slight wider than production helps the engine run better at lower RPM�s by forcing the spark to build to a higher KV before jumping the plug gap & also the spark is slightly bigger.. That helps the plugs to not misfire to begin with so they don�t seem to foul as easily the first time.. Depending on the tractor, age, & ignition system I usually run between .035� up to .040� plug gap.. ~When installing the plugs be sure to clean the threads in the cylinder head or block so the plugs make a good electrical contact with the engine metal & wipe any oil or fingerprints from the top of the porcelain so there isn�t a path for the spark to bleed off down the outside of the top porcelain before it can build high enough to jump the plug gap.. I usually put a dab of dielectric electrical insulating grease inside each plug attachment boot before installing the plug wire to both seal out moisture & make later removal easier.. Any questions on the above just post back or E-Mail.. [email protected]
