2130
p watters
05-27-2004 14:05:27
why dose temp gauge & fuel gauge needles swing about when turn indicator or hazard lights are used.
buickanddeere
05-27-2004 15:09:23
 Re: 2130 in reply to p watters, 05-27-2004 14:05:27
Voltage drop that varies with current/load likely due to a high resistance ground or supply connection somewhere.
P aul Watters
05-27-2004 15:24:30
 Re: Re: 2130 in reply to buickanddeere, 05-27-2004 15:09:23
Thanks, how do I fix it?
buickanddeere
05-27-2004 20:35:30
 Re: Re: Re: 2130 in reply to P aul Watters, 05-27-2004 15:24:30
Easiest found with an analog voltmeter and measuring from the battery's ground post. To the ground side of each device. Find the point where the voltage is more than 1/2 volt above ground or where the voltage varies or suddenly increases. A similar test is also done on the "powered side" to find sudden or changing droops in voltage. Measure from the "hot" battery post along the "live" side of devices looking for sudden or varying voltages above 1/2 volt or so.
