1949 A Help Please
Hank
05-27-2004 08:30:22
This tractor has a power block, cranks 100 psi compression, does not really smoke out the exhaust, and the plugs do not look oily, but when I am using it, the clutch area has smoke such as blow by coming out of it. Light smoke at idle, when you put it under a load, it gets worse. I know it sounds like rebuild time but the other things I mentioned above do not suggest that. Any ideas?
Mike Aylward
05-27-2004 12:04:27
 Re: 1949 A Help Please in reply to Hank, 05-27-2004 08:30:22
Hank, that is low for a Power Block on compression. The factory specification of a late A gas tractor is about 115 lbs. of compression. A PB equipped tractor should run at least 140 or more. If you have blowby problems the rings and possibly the pistons are worn. Depending on the width ring you have on your pistons (there were different thicknesses) the ring grooves might be beat out as well. But these can be regrooved and wider rings installed in many cases. Jerry Hinrich in Lyndon, Illinois carries rings for these pistons in differing widths and is reasonably priced. Hope this helps. Mike
F-I-T
05-27-2004 08:36:18
third party image
Hank:
I haven't had an "A" with a power block for years, but they had a reputation for wearing the bores rather quickly.
Also, oil control rings were often a problem. You might just get by with a nice in-frame honing and new rings. Would not surprise me to see that the oil rings were worn out.
Here's a picture of our original JD on the farm. #595751
Frank
The Dukester
05-27-2004 19:21:48
 Re: Re: 1949 A Help Please in reply to F-I-T, 05-27-2004 08:36:18
Boy, your A is almost a mirror image of my A, S/N 596228.....Cool!
