3020D electrical problem?
Brent
05-27-2004 06:12:32
I have a 3020D that I purchased a few weeks ago. The previous owner had been pull starting it as the batteries were down. I put new ones on it and they goit drained withing about a month. I pull started it a couple of times myself. I was baling hay the other day and blew a line on the hay baler. I shut the tractor down. We tried to pull start it after the line was repaired and it would not start. It would run just a little and then act like it wasn't getting fuel. Is there something in the injector pump that takes an amount of electricity to run or have I really screwed this thing up. I have the batteries on the charger now and am on the way to have this alternator tested. Thanks in advance for any advice.
Jim B
05-28-2004 05:17:01
 Re: 3020D electrical problem? in reply to Brent, 05-27-2004 06:12:32
Brent,if your 3020 is 24V's it is very likely that the starter has a short internally if left battery is the lowest in volts.Jim B
Brent
05-28-2004 07:11:04
 Re: Re: 3020D electrical problem? in reply to Jim B, 05-28-2004 05:17:01
Thanks alot for your comments. I appreciate it. this particular tractor does have a key switch shut off and not the cable type. I charged the batteries up and put them back on. It wouldn't do anything. The lights would work but no starter movement. I guess I need to take aa look at the starter system. Could an internal short in the sarter be what was draining the batteries? Thanks again.
Brent
txblu
05-28-2004 12:05:41
 Re: Re: Re: 3020D electrical problem? in reply to Brent, 05-28-2004 07:11:04
No! Starter solenoid should disengage the batteries unless you are on the start button.
If your light hookup is not doing it (could be a leaking light switch) I'd suspect a voltage regulator problem like a sticking contact that is supposed to open when you cut off power, but doesn't.
That 24 volt system is two 12 volt systems in series. The upper battery connects from the terminal on the side of the starter to the solenoid. The lower battery connects from this same solenoid terminal to chassis ground. Only the generator, regulator, and starter are exposed to 24v. Tractor chassis just happens to be between them electrically.
The rest of the tractor runs on 12vA and 12vB systems; one pos gnd the other neg. Lights on one side are on A and the other B. The inst panel is on the pos ground.
The generator doesn't know that it is feeding 2 batteries in series. It just puts out charging voltage (around 28v) and the batteries attempt to get their share. Any unbalance in the batteries will cause one to get more than the other. Then when the regulator holds the charging voltage at 28v, it doesn't know that 16v of that could be to one batt (way overcharging it and boiling out electrolyte) and 12 to the other (which would not charge the second battery). This unbalance could be caused by improperly balanced loads (1 headlight out on 1 side could do it). I checked mine a couple of days ago and one was at 12.75 and the other -12.81. Batteries, regulator, and generator are new. That's pretty darn close to a perfectly balanced system.
Bob
05-28-2004 18:07:47
 Re: Re: Re: Re: 3020D electrical problem? in reply to txblu, 05-28-2004 12:05:41
The starter solenoid is a single pole disconnect, and DOES NOT disconnect the (+) side of the system from the innards of the starter (assuming factory connections), so moisture, rust, crud, and brush filings inside the starter will drain the battery whose positive post is connected to the belly of the starter.
Dan
05-27-2004 07:20:28
Does that have a key shutoff, in other words you turn the key rather than a cable to shut it down? If so it does have a solenoid in the top of the injector pump. Some of the later 3020s had this setup. It would take some electric current to turn it on but should not require much.
