The KBL disc was a 3 PT mouted disc that that was in the line from about the mid 1950's to the mid 1960's when it was replaced by the "Y" series 3 PT disc's. The KBL came in 5'2', 6"4", and 7'6". The disc spacing was 7 1/8" and could be had with 18" or 20" blades. The 7'6" could be used on say a 520 or a 2010 IF IF IF the tractor had a full set of front end weights. There also was a KBY that was a 3PT disc for the bigger tractors. It came in 6' 7' 8' and 9'. With the 6' beening recomended for the 420, the 7' and 8' for the 520 and the 8' and the 9' recomended for the 620 and 720 tractors. The KBA was of the same era and probley the most popular John Deere disc of that era. It beening a wheel disc that came in 5foot to 14 foot. It was not the heavy duty disc at that time. The heavy duty disc was the RW. As to weather a 60 can pull a 10' disc,,,,, ,dependes on what and where you want to disc. First time over a disc won't cut in two deep, but as you work the soil becomes looser and the disc will go in deeper and pull harder. On sod the first time over, you barly cut into the sod. You should dig sod, not disc. If you have hills, 10' might be quite a load for a 60 as it takes extra HP just to climb the hill. The nice thing about a wheel disc is that you have the wheels and the hyd cylinder to control depth. In our country, if I had a 60, I would runn 2-16" in sod and 3-14" in corn stalks and run a 8" digger and an 8" disc. When growing up as a kid, thats what remember seening behind the late "A"'s and the "60"'s.
