Weight of unstyled A
John
05-26-2004 19:25:37
I have a 1937 A on rubber. Could anyone give me a good guess on the weight. I saw a copy of a sales brochure stating the shipping weight was 4300 lbs. I think this was on steel though. Thanks much,
John
John
05-28-2004 18:44:11
 Re: Weight of unstyled A in reply to John, 05-26-2004 19:25:37
Thanks for the information. I sure appreciate the help I get on this forum.
Duane Larson
05-27-2004 07:58:49
John,
A 1937 Price List for an A on full rubber with round spokes gives a shipping weight of 3683 lbs. If cast rears the weight is 4221. Add 189 lbs if you have a power lift, and 128 lbs for fenders.
Greg in MO
05-27-2004 06:36:37
John,
I have a '37 A as well. I have seen numbers from various sources ranging from 3500 - 4500 lbs. It also depends on things like whether you have calcium chloride in your tires or some other additional weights, which can add several hundred pounds. It's probably around 4000 lbs or so.
Greg
Greengo
05-27-2004 19:06:59
 Re: Re: Weight of unstyled A in reply to Greg in MO, 05-27-2004 06:36:37
I have a 37 A and the last time I had it to a pull with half tank of fuel and me on it, It's weight was 4300 pounds, Has power lift, and flat spokes on rear on 12-38 tires, All stock with no add on weight. Take 160 pounds off for my weight.
