4020 with two shifters or phony?
Harrison
01-27-2004 18:23:54
I seem to remember many years back working with a 4020 that had 2 shifters. One had a park gear,Low range, high range, reverse. I have a friend who doesn't think a 4020 came with this set up,and that it was probably another model with 4020 decals. Was it a phony 4020? Maybe I got that oldtimers thing messing with my rememberer?
Newgen
01-28-2004 06:27:56
 Re: 4020 with two shifters or phony? in reply to Harrison, 01-27-2004 18:23:54
Rich your 8430 has Quadrange--those weren't available until the 30 series.
rich
01-28-2004 05:22:47
i have a 8430 articulated with the same 2 shifters one does the range a to d and reverse and the other does 1234 and park
if that helps you
newgen
01-28-2004 04:28:58
Doug is correct, the JD600, (A.K.A. 4020 Industrial} had the setup you described. Everything is the same inside, it's all in the linkage.
Brokenwrench
01-28-2004 04:10:18
Sure it wasn't a 7020 or 7520. They both use 2 shifters.
jdemaris
01-27-2004 18:53:27
Seems like it wouldn't be hard to do. 4020s, with the SynchroRange trans. have two shifters coming out the transmission. One has the Park-Lo-High-Reverse that you mention, and other one has the gear changes. I've never seen anyone try it, but I guess you could put two sticks in and eliminate all the linkage that Deere uses to control it with one. Deere did use two separate shifters on some of the older industrial equipment, but not on the AG stuff.
720Deere
01-27-2004 18:47:52
I am by no means an expert, but if I understand the way they work, it would be possible for somebody to rig up a shift system like that. I don't believe that was ever OEM. The syncro range tranny works like 4 different ranges with 2 gears and reverse in each one except that reverse is blocked out in the two highest ranges. Maybe somebody had trouble with the shifter linkage at some point and found a home remedy. Possibly this setup made it easier to get one of those things out of that cursed park. I have been on 3020s that it almost took an act of God to get them out of park on a hill.
Maybe one of the many experts on here will give us the correct scoop on this anamoly.
JDGnut
01-28-2004 10:13:59
 Re: Re: 4020 with two shifters or phony? in reply to 720Deere, 01-27-2004 18:47:52
Those 2 reverse syncro's.. have 3 reverse gears.. you have to knotch the shift housing to get it shift in.. (or have a wore out shifter..) I have cut a bunch of notchs for the 3rd R... (even the 30 series syncro's had the 3 rd.. just wasn't notched for it..) JDGnut
Mark
01-28-2004 15:16:47
 Re: Re: Re: 4020 with two shifters or phony? in reply to JDGnut, 01-28-2004 10:13:59
You can do it with a powershift also. Cut the reverse gate all the way up. 8th reverse is a real butt puckerer.
Mike M
01-28-2004 05:31:55
We have a 4020 syncro-range and have a loader,back blade,and fluid in tires so it is heavy.We have never had any trouble getting it out of park even though it does get bound up very often cause of the hills and weight.They are designed with a spring loaded linkage so you can pull the lever back and place it in 1st or low reverse whichever takes you up the hill let out the clucth a little and you will hear it pop out of park then you can put in whatever gear then go.
Rob
01-27-2004 20:15:42
We have owned 3 4020's and a 4010 in the past,and that high range reverse thats supposed to be blocked out wasnt on them.All you had to do was pull that shifter on by 7th and into high speed reverse.Never forced them by.We just discovered it years ago.
doug@upr
01-27-2004 18:41:12
maybe your thinking of the 600 series industrial with the powershift and the shuttle lever.
Mike w J
01-28-2004 07:58:40
 Re: Re: 4020 with two shifters or phony? in reply to doug@upr, 01-27-2004 18:41:12
There is a reverse below 8 th. gear also
Dr.EVIL
01-28-2004 08:24:26
 Re: Re: Re: 4020 with two shifters or phony? in reply to Mike w J, 01-28-2004 07:58:40
That HIGH range 8th reverse should be good for what.... almost 30 MPH? Backwards! YeeeeeHaaaaw. Ridem Cowboy!
