50 JD final drive
Chuck McDonald
05-26-2004 16:52:21
Where is the plug for the final drive? It only takes 1 quart right? Whay is it seperate from the rest of the transmission?
Thanks for everything
Chuck McDonald
Pat
05-26-2004 19:34:53
 Re: 50 JD final drive in reply to Chuck McDonald, 05-26-2004 16:52:21
Hi Chuck! Is it possible that you are talking about the first reduction housing It takes a quart of 80w-90w oil and the fill plug is on top of the first reduction cover housing up by the clutch pulley. if you fill the transmission, oil will seep through the bearings and fill it. But by filling it with oil you are sure to have it at the correct level. If you are talking about the final drives/transmission, it takes about 5 gallons and the fill plug is on the right side of the tractor behind the rear axel. It is a square headed plug about 1 1/2 inches in diamater. Good luck and have fun!
