#5 sickle bar mower wooden pitman
jd35d
05-26-2004 15:27:31
Just got a #5 sickle bat mower with a deteriorated wooden pitman arm? or whatever they call the drive arm under the gearbox to the bar. Are NOS wooden pieces available? Can I make my own and do you have the dimensions? Thanks
Jke
05-27-2004 08:51:22
 Re: #5 sickle bar mower wooden pitman in reply to jd35d, 05-26-2004 15:27:31
The wood pitman is readily available from your JD dealer.
Also some aftermarket ones are available at your local farm supply store or even other brand tractor/implement dealers. The generic ones can be had with all holes ready to go, or there are blank sticks available that you cut to length and have to drill all the holes.
pa_popper
05-27-2004 08:09:44
You can get the dimensions from>Link
It's>Link a pretty neat site with info on B's and the #5 mower.
John T
05-26-2004 15:50:42
Its been a few years, but I used to buy my wooden pitman arms at Tractor Supply and Central Tractor stores, at a better price then Mother Deere, of course. If worse comes to worse, I have a couple No. 5 Mowers scattered here or at Henrys somewhere and could draw a pattern maybe.
John T
iloveihtractors
07-20-2005 19:01:28
 Re: Re: #5 sickle bar mower wooden pitman in reply to John T, 05-26-2004 15:50:42
I was wondering if you had any information on the adjustments that you can make on a John Deere #5 Mower - my father and I are working on one, but he can't remember all of the adjustments that can be made.
Popper Dick
05-26-2004 15:45:28
jd35b
I have a number eight sickle bar mower that I hook up to my 1950 model b. I have no problems getting the pitman arms from JD and the price is very reasonable. Some people call them hickory rods.
Good luck with your mower. Mine works great.
Dick
